Front rotor removal/installation...?
Hey guys... I got a couple of new rotors comin in the mail for my 2003 CBR 600RR, thanks to 04CBR600RR. Now, I just gotta figure out the easiest way to get my old ones off, and the new ones on... I have some brake cleaner and plan on tidying up the new rotors when they get here before I install them. Any hints/tips/tricks for me? It doesnt look like it should be tooo difficult, but you guys got a good way to do it? I dont have a front stand as of yet, so Im going to have to jerry rig some jackstands to make it work for this time... got any other ideas for that?
thanks for any help guys, youve always been awesome at giving excellent info,
Chris
Chris
RE: Front rotor removal/installation...?
It`s easiest with the wheel off, just lay the wheel on its side and undo the bolts then remove the old Rotor. Re-install your new ones and loctite the bolts. then flip the wheel over and do it again for the other side. I havn`t come across any time saving tips yet.
Red loctite. Lay something soft on the ground to keep from scratching rims. If you have an old tire laying around they make the perfect work surface.
And if the 600RR is like the 1000RR with six 6mm bolts and directions say torque to 14ft/lbs .... don't do it!!!! 8ft/lbs is plenty tight. 14 will pop the head right off the bolt. And trust me, it ain't a fun time drilling those ****'s back out[:@]
I'd use blue loctite, not red. The red stuff is made to NOT be removed with hand tools, needs impact, and you don't need anything that strong for those little bolts. Blue stuff will work just fine and you'll be able to get them off again for the next time.
Anyways, I don't have a jackstand for mine either, so I just use 2 scissor jacks from my car and my roomates car (we have identical cars so identical jacks), put one under each fork tube and raise them up evenly. Oh yea the back is already up on the rear stand to help hold it level. Raised it up just enough to get the front wheel off the ground, take the calipers off (2 12mm on each side), pop the axle out and let the wheel just sit on the ground, don't need to take it all the way out (though it definitely doesn't hurt anything, but doing it this way it's hard to get the wheel all the way out). Once all the rotor bolts are out you can just maneuver it around a little bit and slide it right out without taking the wheel completely out. Then just put the new one in, and look at the outside of the rotor there should be a little arrow indicating the rotational direction, so that you know which side is which. Tighten the bolts, put everything back together, and you're good to go! Be sure and torque the axle nut to the proper torque
backdoc
How To ...
21
09-06-2022 01:52 AM
holycrapitshassell
How-To: Mechanical
35
07-02-2009 12:05 AM
