-   General Tech (https://cbrforum.com/forum/general-tech-9/)
-   -   Front Brakes (https://cbrforum.com/forum/general-tech-9/front-brakes-52597/)
drosales007 Oct 22, 2007 11:59 AM
Front Brakes
I just recently replaced my front master cyclinder but am not getting any pressure throughout. Anyone know how to make it work?
Streetdemon Oct 22, 2007 12:04 PM
RE: Front Brakes
Did you bleed the brakes?
drosales007 Oct 22, 2007 12:11 PM
RE: Front Brakes
Not yet, was about to try later on today. Should that be the only problem?
knightslugger Oct 22, 2007 12:33 PM
RE: Front Brakes
I can't believe what i'm reading. you replaced the master cylinder and didn't think it necessary to bleed the brake system? dude, at this point i don't even want you attempting a bleed for fear you'll fuk that up.
sixhundredrr Oct 22, 2007 12:36 PM
RE: Front Brakes
Bleed them. Should be simple enough to do but bring a manual with you JIC. Get back to us on the results.
Streetdemon Oct 22, 2007 04:28 PM
RE: Front Brakes
Yeah that will fix your problem. Bleed the system and you should be all set. Def want to check the manual to ensure you bleed them properly.
drosales007 Oct 23, 2007 05:25 PM
RE: Front Brakes
ok, just got the brakes working. Thanks, but now i'm getting white smoke from my pipe...any ideas what this could be from? Bike was on its side for like 10 minutes after it went down.
snowboarding82 Oct 24, 2007 11:29 AM
RE: Front Brakes
10minutes?!?! Did you let it take a nap?! lol Maybe oil is getting into the cylinders? Or would that be black smoke? I thought white was burning oil though, but what do I know. /shrug
sixhundredrr Oct 24, 2007 11:33 AM
RE: Front Brakes
ORIGINAL: drosales007
Have you changed all your fluids? Some may consider it unnecessary, but it couldn't hurt. It could be oil that go on top of your pistons and it just needs to burn off. Check your oil level to make sure it's ok and let her run for a while to see if it goes away.
Streetdemon Oct 24, 2007 01:58 PM
RE: Front Brakes
If its white smoke....let it burn off. Had the same prob andburnt it off on a short ride.
