front brake bleeding problem
alright so i put new SS lines on my bike. but now i can't get my brakes to bleed at all, the parts are in the correct place and everything is tight. but for the life of me i can't get any pressure and i have absolutely no idea what is going wrong.
so if you have any idea what could be going wrong, please tell me. i'm open to all suggestions......
RE: front brake bleeding problem
Just keep pumping.. It took me like a hour or so. I would fill the res, pump like ten times with no pedal then release a bleeder screw and close it before letting go of the pressure. just keep working on it, it will finely work. some times you can use a power bleeder but they can be a bigger pain in the ***.
good luck
good luck
