f4i help
Old May 8, 2007 | 02:58 AM
bcjoe's Avatar
Default f4i help
ok so i installed new flush mount signals on my 01 f41 and while doing so i turned the key on to see if my wiring was right or not and noticed that the fuel pump was not buzzing or fuel injecting like it does normally , and of course i try and start it and it wont turn over ,(i think i read this post a few times on here already lol) so what im wondering is where this tip over sensor is and also where the fuse box is on my bike (sure its behind one of the fairings , anyways thanks for reading ,
Old May 8, 2007 | 07:33 AM
PHXf4i's Avatar
Default RE: f4i help
fuse box is under your front seat and tip sensor is between the headlights behind the gauges. most likely blew a fuse.
Old May 8, 2007 | 11:08 AM
bcjoe's Avatar
ya thats what i figured , but it was too late and too dark to keep goin lastnight , guess i'll check wehn i get home from work . the tip over sensor ,is it attatched to the upper fairing cause i had that laying down on the ground as i was testing the signals ,could be the way it was sitting , well thanks alot
