f4-f4i body swap?
f4-f4i body swap?
im shure this question has been asked about a million times on here. but i just singed up so im gonna have to ask. im getting ready to swap out the non existing f4 body work for f4i fairings and tail. i do have the side fairings. will they fit to a f4i upper? second qestion. can i use my stock sub frame if i make brackets, or does the f4i tail fight right on? if you have been this route and can give me some heads up before i purchase the plastic your help will be much appreciated. thanks in advance....christopher....x60
yup the sides will fit as they are the same. The upper you may need a F4i stay or have to mod your existing one. The tail depends on what yours has and what you are trying to put on it. If its has a nana seat n you are trying to put the F4i nana seat on then yes it will work just fine. But if you are trying to use a split seat tail with a nana seat subframe, you are better off getting the 01-03 F4i split seat subframe.
