-   General Tech (https://cbrforum.com/forum/general-tech-9/)
-   -   F3 Water pump (https://cbrforum.com/forum/general-tech-9/f3-water-pump-40823/)
Heaton830 Jun 2, 2007 01:04 PM
F3 Water pump
does anyone know if i can justpull thetubes and thentake my water pump out, on my F3without draining the coolant and oil first, or dothe fluids need to be drained before i remove it?
frstplce1 Jun 2, 2007 01:17 PM
RE: F3 Water pump
You will have to drain the coolant. That'll happen if you pull the tubes ;)
Are you changing the pump or what?
You don't need to drain the oil. If it's on upright on a stand. You may lose a little bit, so put some newspaper down or something.
