exhaust wrap
RE: exhaust wrap
The bad side being excess corrosion? I guess it would depend on the application. My vette had certain parts of the headers and exhaust pipes wrapped with no problems, but it never sees rain. On a bike you'd get them wet when you wash it and during rain, so without a doubt it may cause some corrosion issues, but maybe not that bad.
RE: exhaust wrap
The biggest problem is corrosion, unless you have TI pipes, or you can use a high temp silicone spray to seal your wraps from the elements and oil and any other debris. I have my pipes wrapped and the silicone spray is excellent just be sure to cover anything you don't want covered in the stuff.
RE: exhaust wrap
ORIGINAL: tomc1965
You could always spend $100-$200 and have the pipes ceramic coated. Then there are no corrosion worries and you will cut the heat better than the wrap.
Plus if you have the insides of the pipes done(which most shops do).This also helps exhaust flow and is the KEY to keeping the heat in..Plus stops moisture in the exhaust from rusting the pipes.
Plus with wraps if you spill oil on them ,it will soak right in.Coatings the oil can be sprayed right off.
RE: exhaust wrap
ORIGINAL: tomc1965
i am sure however that with the proper amount of scotch guard wrapping should be corrosion free and rather effective...
