exhaust leak
Old Feb 17, 2008 | 11:59 AM
f4ez's Avatar
Default exhaust leak
ok so i did the 01-03 tail conversion on my 06 f4i and i was told that to mount up the exhaust just loosen the clap slide the pipe back and i will be good well thats not the case cause it leaks hella bad so if anyone has any more ideas or knows what i did wrong that would be great
Old Feb 17, 2008 | 03:09 PM
pacemaker's Avatar
Default RE: exhaust leak
Probably need to replace an exhaust gasket. Moving the pipe may have caused it to split & fall apart.
Old Feb 17, 2008 | 08:19 PM
f4ez's Avatar
no the gasket is fine there are slits at the end of the pipe and it leaks through there ill post pics
Old Feb 18, 2008 | 02:05 PM
camoweasel's Avatar
I used high temp (orange) RTV sealent when I installed my slip-on onto the header pipe because even though I tightened the clamp as hard as I could, it stll leaked. Rub some onto the pipe, then slip the pipe over top. It woked great for me.
cschew
Dec 22, 2011 03:04 AM
johnnyx
Sep 14, 2009 09:08 AM
ryandrosa
Aug 22, 2007 12:01 PM
SproutRR
Jun 6, 2007 07:16 PM
907hondaf3
Apr 14, 2006 07:53 PM
