-   General Tech (https://cbrforum.com/forum/general-tech-9/)
-   -   engines dies when put in to gear (https://cbrforum.com/forum/general-tech-9/engines-dies-when-put-gear-70764/)
stuffum07 Jun 11, 2008 01:58 AM
iv got a 1999 cbr 600 f4 and runs fine but soon as you put it into gear it stalls what would be my problem
pacemaker Jun 11, 2008 03:06 AM
RE: engines dies when put in to gear
I suspect you have your side stand still down, it has a cut out, won't start till stand is retracted.
If not the case then the cut out switch may be faulty.
fishfryer527 Jun 11, 2008 04:32 AM
side stand switch.
or
Does anyone know if there is a switch or sensor in the tranny that talks to the motor that tells it whether of not the bike is in neutral?
jDeArMeAmNy4 Jun 11, 2008 05:54 AM
did you pull in the clutch. i wouldnt recommend clutchless shifts into first when your stoped :-)
redzintimidator Jun 11, 2008 07:45 AM
is your clutch adjusted properly? On my dirt bike it was still grabbing a little at full clutch and stalled sometimes when shifting at a stop.
bdphap Jun 11, 2008 01:59 PM
If it jerks when it stalls it may be the neutral saftey switch(maybe called something diff.) if no jerking almost sure side stand switch.
