Electrical Question
Old Nov 12, 2012 | 03:50 PM
ambeos5's Avatar
ROTM, Oct 2014
Default Electrical Question
My bike started its life as a F2 but was completely swapped to an F3 . so im stripping the fairings and redoing junky wiring they did and i have found something i dont have an answer to hoping you guys go
When sitting on the bike on the Right side there is a harness that runs down the frame, there are 2 plugs that have nothing plugged into them one is a white/clear and one is black both are weather proof 2 prong plugs and look identical.
any ideas on what they may go to?
Thanks in advance for any info
Old Nov 12, 2012 | 04:13 PM
streetfighterF4's Avatar
Possibly your throttle body for one?
Old Nov 12, 2012 | 05:17 PM
Conrice's Avatar
not sure bud, but you should look at the wiring diagram. but i can tell you for certain that it's not for the throttle bodies - since your f2 or f3 doesn't have throttle bodies and carbs don't have electrical wiring
Old Nov 13, 2012 | 01:31 AM
ambeos5's Avatar
ROTM, Oct 2014
well i was thinking i run it this alot doing car audio car makers put harness's in that have plug for different engines or options that may not be used on all cars. but ive never ran into this on a bike granted my working experience on the bike is pretty new compared to most here im sure these went to something i dont beleive that the bike harness would have had them if they didnt goto something(i may be wrong)
i also have a looks to be a form of valve just below the airbox that has a electric plug on it but is not plugged into anything thinking this maybe one of the other plugs mate but not sure.
Old Nov 14, 2012 | 05:58 AM
ambeos5's Avatar
ROTM, Oct 2014
UPDATE
a little searching here on the forum and i figured out that was indeed a valve the air intake valve that opens the ram duct at 12mph to the carbs. i am assuming since it wasnt hooked up that it did not function and have found a how to on the forum to bypass it with no side effects.
thankd god for the search options
Old Nov 15, 2012 | 07:05 AM
ambeos5's Avatar
ROTM, Oct 2014
well after looking at the wiring schematic i found out that the air intake control valve was indeed one of the plugs, BUT the other is still a mystery according to the schematis the only other things that use a 2 prong plug on the bike is Pulse Generator,Fuel Pump Relay and Fan Motor so i think i can safely rule out the first 2 or the bike wouldnt run so ill trace the wires from the fan today to see if thats the plug
Old Nov 15, 2012 | 02:58 PM
adrenalnjunky's Avatar
depends on if you have a F2 or F3 wiring harness - I'm not clear on which you have.
but - if you have a F2 converted to F3 - depends on how "completely" the conversion went - the F2 didn't have a fuel pump, F3 did have a lo pressure fuel pump. If your tank doesn't have the pump - that might be the plug.
what would be a million times easier, is tell us what color wires are running into these plugs - could probably find it in a heartbeat.
Old Nov 20, 2012 | 04:37 AM
ambeos5's Avatar
ROTM, Oct 2014
sorry i have been mia last couple of days but heres the colors you asked for:
Clear/White plug : Oragne/blk tracer & Green
Black Plug : Green and Black
Hope this helps
PS there is a low pressure pump mounted and hooked up not for sure how much was swapped to F3 but looks to be a pretty good bit
Old Nov 20, 2012 | 05:54 PM
Hope this helps
Orange/Black & Green wired plug connects to the F3's Air Vent control Solenoid Valve, and the other end of that same cable pair connects to the Air Vent Control Relay. I don't know which end you have, but appears to be a completely isolated circuit if it is not plugged into either the valve or the relay.
Green & Black is plug for EVAP/CAV solenoid valve - which is a piece of emissions equipment found on California model motors. you may or may not have a Cali motor - I guess you would know best if you've got all the smog parts installed.
Old Nov 21, 2012 | 01:28 PM
ambeos5's Avatar
ROTM, Oct 2014
Thanks for all the help, The air valve im going to bypass i found a how to on here and my bike doesnt have the cali emissions so i think im good on the plugs but you never know until you find what they goto i trust my life with this bike so i make sure its done right. Thanks again for the help guys.
Wranghondo
F2 Tech
Feb 19, 2012 12:57 PM
Cbr_BigK
Mar 1, 2011 07:02 AM
cbreric
Mar 26, 2009 07:50 AM
smokingmole
May 1, 2008 07:45 PM
600f4i_blackout
Jan 8, 2008 08:19 AM
