-   General Tech (https://cbrforum.com/forum/general-tech-9/)
-   -   Dyno-Drag Results (https://cbrforum.com/forum/general-tech-9/dyno-drag-results-2087/)
Capone May 29, 2005 04:31 PM
Dyno-Drag Results
01 CBR F4i - Hindle Slip On/K&N Filter
Run 1:
Reaction Time: .558
Elapsed Time: 11.021
Speed: 126.500
Horsepower: 100.2
Run 2:
Reaction Time: 1.277
Elapsed Time: 11.042
Speed: 126.800
Horsepower: 101.3
Run 1:
Reaction Time: .922
Elapsed Time: 10.895
Speed: 127.500
Horsepower: 104.4
I was sad when I seen the HP results. I had another run but my bike was @ 229 degrees, so I passed it up...lol. I'm thinking about a power commander, but is the $300 worth the results? What do ya guys think? Suggestions? Thanks.
RRip May 30, 2005 04:20 AM
RE: Dyno-Drag Results
I dont think there is a ton of HP gain with the PC. It is mainly for a better tune. Be lucky to get 2 or 3 out of it if thats what you are looking for.
Capone May 30, 2005 05:12 AM
I was also running 113 octane which I think also hurt me in the HP numbers. I will run Shell-93 from now on. I also noticed a huge doggyness when I dumped the clutch, I went from 11k rpm to 1500 rpm when I took off on the dyno, I prolly should of slipped the clutch a lil more, but still, I think a PC will help that a bit. thanks for the input!
Turboedsupe May 31, 2005 03:42 AM
Doesnt honda only rate these things at 110 hp? Why are you so dissapointed with your results?
NeonspeedRT May 31, 2005 03:36 PM
It's a 600cc bike. You are not going to get huge gains out of that much you do to it. With a full exhaust, pcm, and some tuning you might pick up 6 or 7 hp max. Bikes now days are so finely tuned it's hard to get good gains without tearing into the motor or adding forced induction of some kind.
Patrick May 31, 2005 04:38 PM
so a friend of mine has an 04 600RR....how much faster would he be in the quarter mile than the F4i? he has a power commander, full exhaust. just curious mostly..thanks.
Capone Jun 1, 2005 09:43 PM
I dunno, I would have like to see better than stock or stock, numbers with a K&N + Exhaust... but I <3 the bike anyway :P
chainstretcher Jun 1, 2005 09:58 PM
Slipping the clutch would've netted better #'s but is hell on a clutch. I'm wondering about your shift points -- RT's are erratic but somehow you managed to make the best ET with the .922 -- almost 1/2 sec slower than the 1st run but best speed, ET and HP. Go figger?
Patrick Jun 2, 2005 04:51 PM
RT in no way figures into your ET...you could sit for an hour when the light turns green...and then launch and pull a good ET.
ET starts when RT ends.
chainstretcher Jun 2, 2005 06:58 PM
You are correct -- I don't know what the heck I was thinking.
