-   General Tech (https://cbrforum.com/forum/general-tech-9/)
-   -   Is this Dent Fixable? (https://cbrforum.com/forum/general-tech-9/dent-fixable-83501/)
Dominate. Nov 30, 2008 11:39 PM
I bought the bike like this so I don't know what happened, but is it possible to pop out this dent on the exhaust? Also, is it worth it to spend the money or should I leave as is?
http://img234.imageshack.us/img234/5586/p1000464af8.jpg
HAVOC Nov 30, 2008 11:49 PM
RE: Is this Dent Fixable?
just cut the pipe into a shorty that will get rid of the dent, make it look better and sound good too
Incognito Dec 1, 2008 12:16 AM
Those slip-ons are re-buildable. You can take it apart and either put a new sleeve on it, or try and smooth the dent out. Here’s a video. I’d try the latter first, and if that don’t work, get a new one, or do as Havoc suggested.
Dominate. Dec 1, 2008 01:30 AM
I can't think of a way to smooth this dent out. And also, how do I make a shorty? Literally just cut the pipe?
Hurricane rider Dec 1, 2008 01:43 AM
yeah you could cut the pipe. but first I'd attempt to use a piece of 1x1 wood on the inside of the can, and push the dent out carefully, then if that fails you could cut it into a shorty.
Dominate. Dec 1, 2008 01:47 AM
I'll try that. As for the shorty, I've looked at some pictures and videos and it seems like people have different versions of their own shorties. I'm not sure if I'm getting this right. If I were to do it, I cut the pipe and just leave out the can completely? or were you guys meaning to tell me to cut a section of the can and re rivet it?
Incognito Dec 1, 2008 01:50 AM
A length of metal pipe put inside the sleeve, and rolledback & forth with downward pressureon astraight surface mightwork too. Definitely quite a little project you got there.
Incognito Dec 1, 2008 02:04 AM
Here's avideo on that too. Yes, you'll have to re-rivet.
HAVOC Dec 1, 2008 02:22 AM
take the pipe off. find a chop saw. cut right above the dent or shorter if you want. take the end cap (closest to the mid pipe) pop off the rivets then drill new holes on the shortened pipe and re rivet. re mount and enjoy.
Endless Dec 1, 2008 01:45 PM
Smaller=louder right?
