cylinder liners advice please
Old Oct 3, 2021 | 03:12 PM
131commando's Avatar
Default cylinder liners advice please
Hi Guys as posted in the content of an earlier thread I removed the cylinder liners from the block on my 600 fk 1989 by putting the block in the oven on full for about 45min and when removed ( with oven gloves on ) the liners just dropped out with sleight pressure however there is a o ring top and bottom on these and I am a bit worried about repeating the heat process for re assembly so as not to damage the new o rings so I was thinking of freezing the liners the day before and only lightly warming the engine block to insert them.
I haven't done this before and watched a youtube video by Alan Milliyard to see how it was done beforehand however there was no mention of re assembly so if anyone here has done this before I would appreciate the advice, cheers Al.
Old Oct 3, 2021 | 05:18 PM
I suspect you're breaking new ground here.
Old Oct 19, 2021 | 01:38 PM
Further to the above posts here's some pics.
One word of advice if your putting bike bits in the freezer or oven DON'T ASK FOR PERMISSION its better to be in bother for just a couple of days than get an emphatic NO !
The pics show why I renewed the liners one severely rusted.
Old Oct 19, 2021 | 04:14 PM
So you were able to re-sleeve the cylinders?
Old Oct 19, 2021 | 04:41 PM
Yes with ones removed from another second hand part, there was non available new and only a few oversize pistons around requiring re bore etc with hardly any rings about. It's not ideal using second hand bits with different wear to the pistons I have but to be fair anything is better than what I had and after honing the bores everything looks good the worst that can happen is it seizes or smokes but then I'll swap over the entire top end if needs be but if you have stripped these bikes down there is hardly any wear normally in the engine it was just that this one had been stood with water/rain in one of the bores for a lot of years that it was so corroded.
Using the oven worked great for removal with only the lightest tap on a bit of wood required for removal and freezing the replacements and just warming the block required no effort to reassemble they fell in by hand.
Old Oct 19, 2021 | 06:24 PM
That is very cool to know. Thanks for sharing that.
Old Jan 4, 2022 | 04:09 AM
jaceiondalen's Avatar
Showbox jiofi.local.html tplinklogin
Old Feb 2, 2022 | 02:24 AM
alidonkaka6's Avatar
Thank you very much.
One piece of advice: if you're putting bike parts in the freezer or oven, DON'T ASK FOR PERMISSION. It's better to get in trouble for a few days than to get an emphatic no.
The photos demonstrate why I replaced the rusty liners.
villa for sale in turkey real estate turkey
131commando
Sep 7, 2021 04:23 PM
elchecbr600f3
Jul 7, 2012 10:01 PM
89HurricaneF1
Apr 30, 2012 09:53 PM
david rosenthal
Dec 8, 2008 09:03 AM
speedfreek
Mar 18, 2008 05:17 PM
