cutting cf can
Old Mar 18, 2008 | 07:08 AM
dannutz's Avatar
Default cutting cf can
Hello everybody,
I'm planning to get a new CF exhaust for my F4i, probably a Two Brothers. I'm planning to cut it a little shorter but I have no idea how to do it or what I need for this... do any of you know more about this? Is there any special tool you need to use to cut carbon fiber? Where do you cut? At the midpipe end or at the back end? Any advice/info would be greatly appreciated. I am a little mechanically inclined so don't be afraid to get technical if you need to.
Thanks,
D.
Old Mar 18, 2008 | 07:50 PM
traitorhound's Avatar
Default RE: cutting cf can
Cut straight. Thats about all I can say. Anything that can cut fiberglass should be able to cut the CF. The only thing you would have to cut is the mesh material that is actually inside the muffler itself. I used an air powered cut off wheel to cut mine down. It took about 20 minutes start to finish along with re-riveting the end cap back on.
Old Mar 18, 2008 | 08:07 PM
DDCavi's Avatar
Saw-zall is great, but like he said, straight cut. Makes it so much easier, better looking in the end.
Old Mar 18, 2008 | 08:36 PM
Mac Pass CBR's Avatar
Why not just buy a shorter carbon can in the first place?
Like this...
Old Mar 18, 2008 | 08:46 PM
dannutz's Avatar
i'm currently also investigating this possibility
i found the scorpion street extreme which looks the best imo but i also like your mivv.
Old Mar 18, 2008 | 09:31 PM
Jason748's Avatar
If you cut carbon fiber, make sure you wear skin & eye protection and a good respirator, because CF dust and shards are NASTY!
Old Mar 18, 2008 | 09:32 PM
The MIVV has a deep, albeit neighbourhood friendlytone below 5500rpm, and completely changes pitch above that when you get stuck into it. IMHO, it sounds awesome when you're on the bike, and even better if you let someone else ride while you stand on the side of the road for a listen!
Needless to say, when going for a fang I keep the revs up a little bit...
Old Mar 18, 2008 | 09:44 PM
inkredibleg's Avatar
Hey .. I cut my yosh trs pipe wich was carbon fiber...
I thought of using a skill saw... a dremel tool ... and a couple other things , but all the fiber dust would get all over the place..
So I used a hand saw .. and worked at it slowly to not create or put alot of fiber all over the place...
hope this helps.
Old Mar 19, 2008 | 05:07 AM
the can used to be this long
Old Mar 19, 2008 | 05:11 AM
ORIGINAL: Mac Pass CBR
Like this...
I have a shorty can because I had a pretty nasty lowside at the racetrack a couple months back so I cut it shorter to where the CF was no longer cracked. It pretty much made it into a brand new exhaust. It obviously made it louder (which I'm not really a fan of) but it works and still doesn't compare to the noise comming from my buddys gixxer.
