-   General Tech (https://cbrforum.com/forum/general-tech-9/)
-   -   Clutch problem (https://cbrforum.com/forum/general-tech-9/clutch-problem-141632/)
Cbr900RR93 Sep 2, 2012 08:12 PM
Clutch problem
Hello Im new to this forum. I have an 93 cbr 900 rr on which I replaced the clutch. I did everything in order and now clutch is not engaging when I put it in gear, bike just dies. Not sure if I installed the judder spring in the correct way, It is bowl side in first. Not sure if thats correct. Clutch lifter piece has about half inch of play when I push it in and out. I really dont know why clutch is not working when I pull the lever and shift into first gear bike dies immediatelly. Please help if anyone can...
Kuroshio Sep 2, 2012 09:17 PM
You checked the kickstand sensor?
CJardine Sep 3, 2012 02:16 AM
when you try to put it into gear does it just die or does the bike jolt or lurch and die. Can you describe it, I had the same issue and for some crazy reason I fixed it by taking the cover off again and putting it back on. I guess the lifter hadn't seated on the pin well. Other than that are you sure you have adjusted the clutch cable properly?
ttemby Sep 3, 2012 05:52 PM
A buddy of mine had a similar problem after 6 hours in the garage we realized the push rod wasnt in all the way i had to move the tranny around until the pin pushed into place try that or maybe you flipped the pusher? if you dont have a lot of motorcycle mechanics skills take it to a shop but try and figure it out the best you can good luck
Cbr900RR93 Sep 7, 2012 09:19 PM
well gentlemen I did take my time to get it right and it was the kick stand sensor in this case. Thank you for the help and I will move on to the next project in a whole new thread lol. Thanks again
