Clutch Engagement Rondomly Changed
Old Jan 14, 2017 | 05:13 PM
SKATEnuggit's Avatar
Default Clutch Engagement Rondomly Changed
Hello, this is my first post on this site and as such I apologize if this is in the wrong section. I have a 2006 cbr1000rr and it has been in my garage since the beginning of November. I went to move it so I could fit one of my cars in and the engagement point of the clutch moved. I have asv levers on it if that's of any usefull info. When I put it in first gear the rear tire spun(dirt on the floor). I had to adjust my clutch lever a bit obver two inches out from the end of the bar. I haven't changed anything and the times I went out to look it over before then have all been fine, but it seemed to have moved anyhow and I can't think of a reason why it would have. If anybody has had a similar problem or any advice on the situation I would be thankful for any help. If any more information is needed I can provide that as well.
Old Jan 17, 2017 | 02:47 AM
tigertim20r1's Avatar
if a bike sits for a while, the oil can drip away from the plates, and the clutch can sort of seize up a little bit. That can leave you with a lever that feels different than it used to.
Happens to a lot of bikes
Old Jan 17, 2017 | 04:48 PM
I did notice I was able to move the lever closer to the position I had it before after it ran and I got it moving a bit, thank you for helping this issue make sense to me.
Webbie1
Jul 3, 2016 04:33 PM
nsrt4me
Aug 25, 2010 12:16 PM
supersnake83
Jul 5, 2009 01:56 AM
cloudbreakmd
Jun 7, 2007 05:43 PM
Stray Cat
Sep 21, 2006 10:28 AM
