Clutch engagement point
Old Jul 2, 2016 | 10:11 PM
Webbie1's Avatar
Default Clutch engagement point
I've noticed that my clutch doesn't start to disengage until the lever is more than half way back to the bar. When I rode it home initially, the clutch lever went all the way to the bar without disengaging the clutch....luckily I didn't have to stop. After the bike cooled down (this was prior to my coolant flush which fixed the cooling issue) everything was fine. It disengages and engages just fine, but I just wish it would disengage sooner as I pull the lever in. I know it's hydraulic, but if it were cable it's acting like the cable is loose and not disengaging until the lever is half way back. What do I need to check? The level in the reservoir looks a little low....about halfway down the view window. Could is just be low on fluid?
Thanks in advance guys,
Warner
Old Jul 3, 2016 | 04:33 PM
Webbie1's Avatar
Never mind.....it was just low. I popped the cover off, filled it up with DOT4 brake fluid and all is well with the CBR world again.
Warner
adrenalnjunky
F2 Tech
Jan 10, 2011 08:48 AM
cloudbreakmd
Jun 7, 2007 05:43 PM
Stray Cat
Sep 21, 2006 10:28 AM
Destinmatt
Apr 13, 2006 05:02 AM
TEN
Jan 23, 2006 01:03 AM
