Changing sprockets
Old Apr 12, 2006 | 09:46 PM
mirks's Avatar
Default Changing sprockets
Hi,
Can anyone give me any info on changing the rear spocket. does it effect the performance or what? im told it helps speed, but lowers the torque. do you think its a good thing to get a smaller one, then i guess youd have to get a new chain or take a link out.
any help would be good
thanks
Old Apr 13, 2006 | 01:22 AM
DThompson's Avatar
Default RE: Changing sprockets
You dont need more top speed on this bike unless you are going to be drag racing for a long ways.
Anyways, Adding teeth to the rear sprocket will give you more torque but take away top speed
Taking teeth away will give you more top speed but your accelleration will drop.
Basically, you add teeth and the bike will do easier wheelies, you take away and it probably wont stand up.
Old Apr 13, 2006 | 01:30 AM
mirks's Avatar
cool thanks.
so would you just recomend keeping the spockets stock?
Old Apr 13, 2006 | 01:16 PM
denhou1974's Avatar
Here's a good reference for gearing.
[IMG]local://upfiles/3662/71E8467D97CF40CCA5D3817B4C34959B.jpg[/IMG]
Old Apr 13, 2006 | 03:27 PM
Anubis's Avatar
Just to clarify .... LOL
Loosing teeth from the front sprocket has the same effect as gaining some on the rear, the ratio is usually about: -1 front = +3 rear.
You will lose top end speed as sacrifice for faster acceleration.
Old Apr 13, 2006 | 04:13 PM
philly's Avatar
Dont forget that it also changes the speedo reading & the distance travelled readings.
Old Apr 13, 2006 | 07:06 PM
denhou1974's Avatar
I went down one tooth on the front for a certain track that I go to (lot's of turns, short straights). Let me say that you can definately tell the difference.
Keep in mind that changing the tooth count will make your chain longer or shorter (so to speak). I was able to go -1 in the front without modifying the chain. I did have to move the wheel way back though. Adding teeth in the back would correct this problem.
Old Apr 13, 2006 | 08:09 PM
brian's Avatar
what would happen if you say, just for arguement wanted to be creative, and put a strange combo on a bike, would it not only cause performance damage ,but would it cause engine damage?
Old Apr 13, 2006 | 08:14 PM
denhou1974's Avatar
ORIGINAL: brian
Going smaller in the front does put more of a strain on the engine. I wouldn't go down more than 1 in the front.
Remember riding a 10 speed ... small gear in the front and big gear in the back is real hard to push but will make you go faster.
BRRandon
Jun 9, 2008 09:28 AM
F4itanner
Mar 7, 2008 11:51 PM
Stockrocket
Feb 18, 2008 05:54 PM
milko
Oct 25, 2006 02:12 AM
rrasco
Apr 8, 2006 02:02 PM
