View Poll Results: Changing engine oil hot or cold? Whats better?
Change your oil while its hot, after a nice ride.
17.95%
Change your oil while its warm, start it up let it run for a short while.
29
74.36%
Change your oil while its cold, let it sit overnight and cool off.
7.69%
Take your motorcycle to a shop and let them handle it.
0%
Voters: 39. You may not vote on this poll
Changing oil warm or cold?
I'm a do-it-yourselfer and plan on changing the oil in my 2009 CBR 600RR my self instead of taking it to a shop.
Heres my question:
Should the engine be started and warmed up to operating temperature before draining the old oil.
OR
Should the engine oil be drained while its cold?
Heres my question:
OR
i'm kind-of a person that takes the bike out for the ride (shift through every gear a few times). I bring it back home to sit for about 30 minutes so the engine can cool just a bit before i unplug and drain the oil. seems oil would be alot easier to drain if it's warm/hot rather than cold (if you live in a 4 seasons area - not like las vegas)
I dont think draining it while it's cold would hurt anything but who knows.
Oil should be changed when warm for a couple reasons. First, it gets the oil flowing a bit better to get it all out, but more importantly it mixes up all the crap in the oil so when you change it, it also comes out.
I let it sit for about a half hour or so to cool down after a ride and then change it.
Nothing like an oil burn, some bike are better than others for removing the sump plug. Unfortunately CBR's aren't one of them.
ehh i havent had a problem with burning myself - i use alot of rags and have extension sockets so i never touch the pipes. I also put a fishing magnet on the extension socket so it will "grab" the bolt when the oil pours out and tries to knock it out of the socket itself (no one likes fishing for their bolt in hot oil)
I also usually rock the bike side to side when it stops draining to get that "last" little bit of oil out. (usually oil gets on the pipes, which on start up causes it to smoke.) I have my hose on hand to spray down the pipes when they start to smoke (just in case of fire). But recently been cutting strips of the rags and taping them to the inside of the pipes (where oil tends to drop on) helps out alot IMHO.
just how i do mine though..
