CHAIN QUESTION
WILL A GHAIN FROM A 600RR FIT A 96 900RR
RE: CHAIN QUESTION
Chain fitment depends on these things:
1. Wheelbase 2. Chain size (520, 525, 530) 3.Front and rear sprocket size 4. Number of links in the chain. If each of these aspects is identical between these two bikes then yes, the chain will fit. However, its very unlikely that this is the case. |
RE: CHAIN QUESTION
Why? What could you do with a 600rr chain on a 900rr? I hope your not using a used one because normally most people just buy a new chain and sprocket kit when replacing the chain.
RE: CHAIN QUESTION
This area is for HOW-TO posts only... and by "How-to", that's not "How do I do this?" questions, it's "This is how you do this" posts. Please read the sticky at the top. Questions should be posted in the "General Tech" forums.
RE: CHAIN QUESTION
ORIGINAL: 900RRHighlighter Why? What could you do with a 600rr chain on a 900rr? I hope your not using a used one because normally most people just buy a new chain and sprocket kit when replacing the chain. |
RE: CHAIN QUESTION
never mind put it on along time a go cut out some links works perfectly and was used 30 bucks ^^ and what dude said if u ride a new bike around the block for 5 seconds the chain is used what ur gonna take it off and buy a new one uhhhh
| All times are GMT -5. The time now is 09:57 AM. |
