Chain O-Ring problem
Hey guys i was wondering i am missing a few O-Rings on my chain and wasnt sure if i should replace it or just let it go for now. Will it damage the sprocket if i dont fix it soon or will it just not lube the chain properly?
-Jared
-Jared
Ditto. Just keep an eye on the tension and change it at your earliest opportunity. If you've got o rings missing then a) you've got bloody good eyesight and b) it's well past its use by date.
Should be replacing the sprockets with the chain. The wear pattern on the current sprockets will affect the chain and vice versa.
The uneven wear while the new chain and old sprockets adjust to themselves will be more than the wear on the old chain + old sprockets. Just don't ask me how much it'll knock off the new chain's life.
lol no thanks, i will do just that i will replace the sprockets and chain thanks for the input. So i will go and ride till the new stuff arrives
