Hi you need to check the voltage at the harness connection, with your multimeter check the yellow/red and green/orange that you have 5vdc coming from the ecu, also check that you have 5vdc on the pink wire from the ecu,
Okay so it seems I missed checking a fuse, the starter relay fuse was blown, I poped a new one it and gauges turned on but the fuel pump did not prime, the bike did also turn over.
Hi, yes it is, I put the key in and turn it, the speedometer lights up and clocks out and goes back to zero, the bike does turn over but doesn’t start. Could it be that the throttle cable is broken?
No thats not your problem , you need the fuel pump to prime , did you try swapping over the Fuel Pump Relay with the Headlight Relay, what sort f front end damage have you had to repair
