CBR600f3 with 954 engine
In addition to the frame. the swing arm can not handle that kind of power either. The F3 has an unbraced swing arm, which are usually only rated for a little over 100hp max. If you've ever looked at a bike that has over 100hp, they generally have braces. You would have to fit a stronger swing arm on the bike as well.
By the time you do all of the modifications, you'll end up with a lot of money spent on a bike that is heavier than what a stock 954 is. The F3 chassis is quite a bit heavier than the 954 chassis. So, the only benifit you would get is a sleeper bike.
If you have both the engine and the F3 chassis right now and want a liter bike, I'd suggest selling both and buying one, or finding a 954 chassis to drop your engine into. I would not waste the time on the swap.
