Cbr1000rr
Need some help guys. I purchased a 2008 CBR1000RR front end for a cafe conversion and found out that no bearing conversion is available for 2008 and up.
Question: Will a triple clamp from 2007 work with the 2008 forks? Any other options?? Thanks John |
The whole tree?
It should if you're using the whole tree. And did you just plug N play with allballsracing? If you call someone there, they can actually tell you. And give you better information... If the stem is too long, I'm sure you could press in one that'd work for the '08 trees you already have. Baring the stem being too long, I can't see a whole lot of reasons the '08 front wouldn't work. |
| All times are GMT -5. The time now is 09:41 AM. |
