CBR1000F 1989 leaking after winter
1 Attachment(s)
Hi folks, went to take her out for the first time after winter storage and fuel was leaking out the bottom. Took the fairings off to take a look and caught this video. Imagine it’s the carbs that needs cleaning but would like some expert advice :)
That's a deluge, are you sure it's from the carb overflows or could it be from the petcock or a split pipe?
If it's from one of the carb overflows then try tapping that carb with a soft mallet to release the float. |
It could be almost anything. You need to get to the actual source of the leak. It could be a fuel line that is dry-rotted, a rodent could have chewed through something, or anything else. I think you're going to need to break it down a bit more before you know for sure.
Originally Posted by Ed Harris
(Post 1363493)
If it's from one of the carb overflows then try tapping that carb with a soft mallet to release the float. that being said it only happens when the engine is on, does that rule out anything? |
Originally Posted by hamlin6
(Post 1363494)
Originally Posted by CBR1000 New
(Post 1363495)
I haven’t a clue where it’s from to be fair mate but it’s only when running. I suppose it could be from a split pipe. It’ll be easier if I take the tank off I think to see won’t it?
(Post 1363497)
It rules out a split in the tank - it’s only happening when there’s a vacuum on the petcock so everything before that is OK.
https://cimg5.ibsrv.net/gimg/cbrforu...b691701027.jpg |
Also, now the tank is off and there isn’t a way to run the engine to see the leak, how can I know for certain where it’s from? Worth taking carbs out of is that overkill for this stage
https://cimg3.ibsrv.net/gimg/cbrforu...6e5d17a1d.jpeg
This looks a little wet? What is it? Does anyone know |
| All times are GMT -5. The time now is 03:12 AM. |
