CBR F3 SOUNDS LIKE A BUELL, NEED HELP
My 95 cbr f3 was running good one day and the next day i started it and it was idling a little low and everytime i gave it gas it seemed like it wanted to die at low rpms, so i adjusted the idle with the **** and it didnt seem like it was doing anything and then it died.
Now everytime i start it, it only idles when the choke is on. As soon as i turn the choke off it dies. And when the choke is on, whenever i give it gas it sounds like a buell or something. I'm not sure what the problem is.
RE: CBR F3 SOUNDS LIKE A BUELL, NEED HELP
My guess is that the plugs were fouled, and changing them will get you riding again. I'd clean the carbs just for fun, and if you have a sync it sounds like the carbs DEFINATELY need some tuning. But it's oil on the plugs, you have a bigger problem.
It started when you put new plugs in it? You'll need to fix what's causing the plugs to foul or you'll have problems with valves, etc., shortly.
