CBR 600 wont start after 8 months off road
Old Feb 2, 2016 | 03:55 PM
BigMal's Avatar
Default CBR 600 wont start after 8 months off road
I have a 94.
been off the road for over 6 months, I've charged the battery and it has petrol (turned on).The battery is trying to start the bike but nothing is happening, any ideas?
Old Feb 2, 2016 | 10:14 PM
coalminer frank's Avatar
Is the kill switch switched to ON? Is the petcock turned vertical?
Old Feb 3, 2016 | 12:53 PM
BigMal's Avatar
yes and yes.
Old Feb 3, 2016 | 09:53 PM
Mattson's Avatar
Most probably your carbs have gunked up and the jets are clogged so you need to take it apart enough to reach the carbs, take the carb bank off the bike, flip it over, open the float bowls and clean all the jets.
Also once you're down there it would be a good idea to swap your plugs since the bike is already apart.
Old Feb 3, 2016 | 10:06 PM
It doesnt even kinda fire at all? Try pulling the fuel line off of the carbs and the vacuum line from the engine to the petcock, leaving it connected to the petcock and start sucking on it with the fuel valve vertical. Fuel should flow out of the fuel line. That would tell you your getting gas to the carbs. But if you do what Mattson says you'll know if you're getting flow when fuel runs everywhere when you pull the carbs.
Old Feb 3, 2016 | 11:58 PM
Mattson's Avatar
Haha yea well forgot to mention DRAIN THE BOWLS FIRST . I did write that @5:50 squinting over my morning coffee...
But yea check your petcock as well.
Old Mar 14, 2016 | 04:40 PM
treoff's Avatar
Did you check for spark?
That_FatCat_Flarm
Apr 22, 2014 11:36 PM
Sebastionbear1
The Hurricane Saloon
Sep 5, 2013 02:22 AM
Naga_Thai
14
Sep 23, 2009 08:58 AM
Jaybird180
Nov 20, 2008 03:38 PM
crazyhorse95gt
Apr 23, 2007 12:17 PM
