CBR 125 no ignition
Old 12-09-2018, 02:07 PM
Louie Richards's Avatar
Default CBR 125 no ignition
Hi all,
Ive got a CBR 125 and has been parked up for a few days. I came to it this morning to start it and there was no power to the ignition when I turned the key. I was told it could be a flat battery or main 30A fuse and so replaced them both and yet still nothing.
can anyone help please?
Louie
Old 12-10-2018, 02:58 PM
wes 17's Avatar
Prove your battery voltage. Check kill switch(es). Carefully check your wiring away from your battery.
By “ no power to the ignition “ do you mean that no lights appear on your clocks or do you mean that nothing happens when you hit your starter button ?
Best of luck mate and post your findings back.
Old 12-10-2018, 06:09 PM
There is no kill switch on the bike and the battery is brand new and fully charged
I mean that there are no lights or anything at all on the column and won’t bump start or anything. The main fuse is fine but changed it anyways and still nothing
cheers mate
louie
Old 12-11-2018, 02:58 PM
wes 17's Avatar
A visual inspection looking for unplugged wiring loom blocks might turn up something. If they haven’t been unplugged correctly in the past, the locking mechanism could be damaged and may cause an issue.
Further, you can also check for your negative (ground) wire connections.
I understand you have a new battery but you should prove your voltage with a meter. The same meter could then be used to prove your fuses and continuity of your wiring.
You might need to partially strip your bike to get at your wiring connections as you proceed with your checks. First check for me would be that I do actually have twelve volts .
Best of luck mate.
Stickypicks845
06-03-2018 04:10 PM
DMcRMX
06-08-2009 11:29 PM
newnut
05-02-2008 09:29 PM
all_squirled_out
11-05-2007 01:20 PM
MuNkY6913
06-07-2006 05:46 AM
Quick Reply: CBR 125 no ignition
