can bike start with no oil?
Old 01-29-2011, 11:51 PM
kinglee86's Avatar
Default can bike start with no oil?
bike wont start and just noticed theres no oil as in DRY!!!!
Old 01-30-2011, 12:04 AM
nuttynu's Avatar
January 2012 AND 2013 Ride of the Month
Put oil!!
Old 01-30-2011, 12:21 AM
morpheus's Avatar
Old 01-30-2011, 12:26 AM
PlayfulGod's Avatar
I'd check the drain plug and then PUT oil in it
But yea they can start w/o oil but its not good fer as you prolly know
Old 01-30-2011, 01:05 AM
hard2obtain's Avatar
Hopefully you didn't hurt your engine
Old 01-30-2011, 10:22 AM
Sprock's Avatar
No start - No oil - does not sound promising & cam's as CBRClassic mentions is where
the damage happens first in most but not all cases. Hopefully it was not ridden with no
oil in it.
Old 01-30-2011, 11:10 AM
600F4inoober's Avatar
Funny this thread came up as I was wanting to post my latest experience. I was planning on doing my oil change. I planned on doing it in the late afternoon but ending up getting tied up, then too tired. The bike sat over night (or an easy 12 hrs) thus most all the oil was drained into the pan (of course there was still some floating on the cams/rollers etc Im sure) but I went ahead and pulled the plug that morning. Let it drain for about 2 hrs as I watched da bears..Went and swapped the filter, wiped it all down and filled er up with 3.7Qts Mobil 1 4T. Upon FIRST start I heard a metal on metal scraping for about 3.6343 seconds. It went right away after the oil got pumped into the once dry before locations. I am assuming it was my piston rings against the cylinder wall? No loss in power or any sign it affected the motor/bike in any way to date..if anything, I'll chalk it up to it gently scraped any carbon deposits or blemishes off my cylinder wall I also, read that from the F4 to the F4i motor one of the changes was looser clearances between cylinder wall and ring for smoother travel.
So for future reference, I understand some say that you should start the bike up real quick and let it run for 30 seconds before you do an oil change. I get the theory behind it, but wouln't that mean that you never really get the most oil out of your case upon changing?
Old 01-30-2011, 11:39 AM
TimBucTwo's Avatar
On some engines there is an oil pressure cut-off switch that will kill the engine before damage is done when pressure drops. I believe the old CB750K with the dry sump had this feature.
Here is what will happen. The spacing between the connecting rod bearings and rod journals as well as the spacing between the crank bearings and crank journals is small. That space is filled with an extremely thin layer of oil. Oil can't be compressed so this thin layer becomes a link between the two but also lets the rod or mains bearings spin around the journals. Without the oil filling the small void, when a cylinder fires, the piston is slammed down, in a violent explosion, against the connecting rod and in turn slams the rod bearing against the rod journal. This smashes the bearing material to the point that the spacing gets bigger and the slamming gets worse. This continues until all the bearing is smashed out. Then the rod starts to trash the journals and the entire crank needs to be replaced as well as connection rods. Depending on RPM and engine load, it can happens in seconds.
A dry cam or dry cylinder wall will have enough oil for a short period of time if oil pressure drops but the crank needs to be feed oil all the time due to the heavy beating the pistons are giving it..
Always check your oil.
Old 01-30-2011, 12:40 PM
justasquid's Avatar
How did you check the oil?
Most bikes won't register oil unless it was run first. the sight glass will be empty as the oil will drain back into the pan after awhile. If you were looking the sight glass, and hadn't run the bike, there is probably oil in there, your just not seeing it.
The theory behind that is to get the oil warmed up so it flows out of the crankcase better, and so the particles that are in the oil are suspended in the oil and come out with the oil. If the oil has been sitting for a period of time, the particles all fall to bottom of every nook and cranny and you won't get them all out with the oil. I usually let it run for a little longer, around 1-2 minutes. Long enough to get the oil warmed up some so it flows better, and to make sure all of crap is coming out with the oil.
Quick Reply: can bike start with no oil?
