Bulb blowing
Old 09-01-2018, 12:25 PM
cips007's Avatar
Default Bulb blowing
Last couple of days my dipped headlight bulb on my 03 Cbr600rr has blown 3 times!!
it comes on with ignition turned on and also after a ride,but the next day I turn it on it’s blown again and also once during a ride out.
anything I should be checking,I’ve not touched the glass at all while fitting the bulb
thanks
Old 09-01-2018, 01:06 PM
74demon's Avatar
Check you charging system output voltage. I would bet it's too high due to a faulty regulator.
Old 09-01-2018, 01:30 PM
cips007's Avatar
If it was the regulator would it not blow both headlight bulbs?
ill check voltage tomorrow,what figures am I looking for please?
Old 09-01-2018, 04:10 PM
74demon's Avatar
between 13.5 and 14.5.
Old 09-01-2018, 04:26 PM
cips007's Avatar
Ok thank you,these readings should be at approx 3000rpm?
Old 09-01-2018, 06:09 PM
74demon's Avatar
I'd check it at a range of rpms to see how high it gets.
Old 09-01-2018, 06:15 PM
cips007's Avatar
Ok will do
the wiring looks sound,but may check the con block that fits onto the bulb and see if any issues with that too
thanks
Old 09-02-2018, 06:32 AM
cips007's Avatar
I’ve just done some battery checks,ignition on is reading 12.4,engine running is reading 15.3 and reving the engine is approx 17.0,but not really used a meter before,have I got it on the correct level/setting in photo
Old 09-02-2018, 08:54 AM
74demon's Avatar
You have it on the right scale, and that is way too high. If you keep running it, blown bulbs will be the least of your problems.
Get a new regulator a retest.
Old 09-02-2018, 10:04 AM
cips007's Avatar
Oh is that dangerously high?
is an after market one ok,like this on eBay 232535336617 or do I need a specific one?
Quick Reply: Bulb blowing
