Broken Bolts
I broke two of my exhaust bolts and came across this site that had good info on broken bolt removal.
I havent been successful on removing mines yet, but found out that it may take up to a week before WD-40 can
penatrate the rust. Not in a big rush to ride the bike yet. Still got to get other stuff done first.
heres the link, could come in handy someday.
http://www.asashop.org/autoinc/may2003/techtotech.cfm
ORIGINAL: Tong3
how does it work?
just curious, cause I'm just spraying it with WD-40 and leave it alone for the weekend
cause I'm going home. If it doesnt work them I might try that thing you mentioned.
how does it work?
ORIGINAL: Deimos
Hey you might wanna try some stuff called "PB Blaster". It runs circles around WD-40. I have never had much luck with WD-40 on rusty bolts. I use it on header bolts and flange bolts for cars, it works great. Good luck.
yeah, just got back from visiting family in Ca. over the 4th
when I got back, I was not as motivated to fix my bike...
but a friend said he would help me load my bike onto the back of his truck so
I could bring it to the hobbie shop and use their torch.
Oh yeah, thats the approach i am using - torching the tips of the bolt, then quenching them
with water to shock them and to break the rust.
In theory it would work, I'll give a try and see.
should have results tommorrow.
yeah I have a 93 CBR and the bolts look as tho they are metal and not aluminum.
The head looks as thought it is, but I plan to heat the tips only and not even to the point of
cherry red, may be just 20 sec on and quench, tap with a hammer, then double nut the bolt.
I'll let yah know what works the best.
