brakes
Old Jul 28, 2014 | 07:58 PM
devares28's Avatar
Default brakes
Hello when I ride my old girl 89 cbr 600f1 she moves but when I slow down and speed up I hear a squeaky noise. Breaks are not squishy, still very firm. I do admit I let her get rained on once or twice the problem developed after that. I am gonna clean the pads and caliper then stick the pads back on or new ones if they look bad.
Old Jul 29, 2014 | 03:46 AM
wheelnut's Avatar
Welcome Crew
if the brakes are not binding they may be just brushing the discs a strip and clean should sort it, I would get the wheels of the ground and see if the squeak is front or back, and check the wheel bearings ect
Old Jul 29, 2014 | 07:05 AM
devares28's Avatar
Sounds good, I will do the first as I do not have a motorcycle stand.
Old Aug 4, 2014 | 08:15 PM
devares28's Avatar
Well I found my problem my rear sprocket was coming off. I fixed.it did a little rear brake work the pistons worked fine after dot3 fluid. I can stop the rear wheel with the rear brake peddle, though I would like a little more play in the rear pistons they work fine now.
Old Aug 6, 2014 | 07:52 AM
Conrice's Avatar
What do you mean by "my rear sprocket was coming off"?
Nytmr
Dec 21, 2013 09:16 PM
CBRInfantry
Feb 7, 2011 09:42 PM
hopz
Jun 4, 2009 01:28 AM
radvoem
Dec 28, 2008 08:38 AM
