Brake light wont work after blinker install..
I installed some flush mounts on my 06 cbr600 f4i. So heres what I did, the flush mounts are 2 wire but old ones were 3, so I cut off the old connector, twisted two of the wires together and connected it to the new 2 wire blinker. Now my blinkers and my rear blinkers are on 24/7 kinda like daytime running lights. Also now my integrated rear brake light doesnt work and it just lights up orange. Doesnt light up red like its supposed to when I hit the brakes. What did I do wrong with the blinker Install? I figured two of the wires were grounds so I just connected them and it works but my brake light doesnt.. help pleaseeee
I didn’t use any kit I just used the old connectors from the old blinkers and spliced them together, do you have a link to any wire adapters that will work? They are two wire blinkers.
the only problem is.. the old connector I used broke and I only had like half an inch of wire left on it so I soldered in some 18ga wire into the 2 wire connector so i’m kinda screwed on that.. id need a new connector, if theres any aftermarket solution id rather do that
Your going to have to somehow extend the two wires that you joined together into a connector that could be easily taken off when releasing your fairings, any way that will lengthen the 2 orange and blue wires will work, here in the UK we dont have the running lights so I dont know how that affects you legally
