Brake fluid
I was wondering what kind of brake fluid i should use, I am going to be replacing my brake lines with those kevlar brake lines and was just wondering what type of fluid to replace it with, Should i use the honda brand or can i go to autozone and pick something off the shelf from there?
RE: Brake fluid
DOT 4 NOTHING ELSE
RE: Brake fluid
I've used Motul RBF600 on an automobile and it worked great. Just be prepared to flush the system often.
RE: Brake fluid
you can use DOT 5 Synthetic if you like but make sure you flush all the old mineral brake fluid out 1st
RE: Brake fluid
Please, any that knows how much brake fluid you have to put in the upper part of the bomb ?
Where is the limit in the glass eye ? |
RE: Brake fluid
I am going to do a full fluid replacement on my CBR 600 F4 this winter and I am going to use DOT 5. I use it in my Goldwing and old 750 K3 and I find absolutely no down sides at all.
RE: Brake fluid
non at all as long as you flush the old mineral stuff out 1st, you'll have no worries,
| All times are GMT -5. The time now is 07:04 AM. |
