Blue fuel? What is going on in my bike???
OK, the rabbit hole keeps getting deeper. I have had a problem where my '91 F2 would quit on me after riding the freeway for 10-15 mins. The problem has been getting progressivly worse to the point where the bike doesn't want to start and is missing pretty bad. I crack the throttle at idle and it dies. Pull it apart to check my plugs, as it was missing and logically I check them. They were fouled. Replaced them, easy enough. This is where it gets wierd...
I pull the tank to the side and decide to flush it out in case there was sediment in there plugging the fuel from getting to where it's going. I take a hose to it and blue comes flowing out the bottom of the tank. BLUE?!? It stains pretty good, as it is still on my hands after soap and water. Poured fuel in the tank and swished it around. More blue. Not just a hint of blue, but like I kept one of those blue toliet pucks in my tank to keep it blue.
So the plugs are replaced and the tank is flushed out clean. Still same problem. Idles like crap and dies when you touch the throttle.
Any ideas?
Also, I went to get some plugs from the Honda dealer and they upsold me a fuel filter. Can't find anyplace to put this damn thing. The fuel line from the tank to the intake is maybe 6" at best and no where to put the thing. It's a plastic inline style filter. Thanks in advance.
Any ideas?
RE: Blue fuel?
2 stroke mix in a 4 stroke motor won't destroy didly, it'll just make it run like crap. To be safe, Run a bit of seafoam or fuel line cleaner of your choice, and it should clear up. Basically, running 2 stroke in a 4 stroke motor is like running diesel or kerosene, the oil content makes it harder for the fuel to burn. It will not mist into the cylinder head as it should, thus creating a less efficient (crappy running) detonation.
Trent Dog
06-13-2012 11:55 AM
sonyab523
05-15-2008 12:44 PM
