Bleeding brakes !!!
Old Apr 6, 2014 | 10:11 AM
choppaclark's Avatar
Default Bleeding brakes !!!
Hi, im having trouble bleeding the front brakes on my cbr 900 rrx, ive just fitted some braided lines and ive been trying to bleed them for the last 3 hours. I have followed the haynes manual method of pumping the lever five times holding whilst opening the bleed nipple then shutting again, ive got a clear hose attached going into a bottle of fluid and the top removed from the master cylinder. I am getting fluid through the lines but im not getting any pressure on the lever, questions ;
1) Am i doing anything wrong ?
2) Is there a way of bleeding the master cylinder ?
3) Or do i need to get off this pc and bleed some more ?
Old Apr 6, 2014 | 10:22 AM
gtcole's Avatar
Welcome Crew
Easiest way to bleed brakes is fill the reservoir, leave the cap off, and open your bleeder nipples. Gravity will pull the fluid down to the calipers. Once you have a steady drip, close the nipples and proceed to bleed as normal.
Old Apr 6, 2014 | 11:14 AM
ok thanks how long should i leave it like that for ?
Old Apr 6, 2014 | 12:05 PM
gtcole's Avatar
Welcome Crew
It shouldn't take too long honestly. Make sure to keep an eye on the reservoir and keep it full. I'd say 20 minutes max. If it takes longer then there is a possible block in the line
Old Apr 6, 2014 | 10:58 PM
Conrice's Avatar
If you get stuck again with you not being able to build up any pressure -
        Remember, just go slow, and you'll get a good lever. That's half the reason they sell those jugs of fluid so big. They know you're going to waste half of it - even when doing a car or something.
        Old Apr 7, 2014 | 12:58 PM
        Well I got there in the end had to crack open the top banjo bolt to bleed the reservoir worked a treat. Thanks for the help folks much appreciated.
        fireblade00
        Apr 22, 2009 02:06 PM
        Jadyone2
        Apr 22, 2009 11:09 AM
        stunter411
        Nov 2, 2007 11:40 PM
        malik987
        Sep 17, 2007 10:25 PM
        Ricepowered01
        Oct 26, 2005 12:02 PM
