Bike won't kick over with new battery
Old Dec 23, 2016 | 10:23 PM
Michael James's Avatar
Default Bike won't kick over with new battery
Okay my problem I have is on my 08 CBR1000rr the bike will start using a jump start but won't with out the boost my battery is brand new top of the range CCA 195 AH6.5 should be no problems with the power of battery, All my fuses are fine, My stabiliser is fine I don't know where to look for go from here ether starter motor or stat anyone had this problem.
Old Dec 23, 2016 | 11:56 PM
CaBaRet's Avatar
Have you looked at the 30amp fuse on the starter relay switch/solenoid, if thats ok try bridging the starter relay posts to see if the engine will turn over, if it does then you need a new starter solenoid, watch out for the sparks and dont bridge to long, you can find a video on how to do this on Youtube
Old Dec 24, 2016 | 10:13 AM
74demon's Avatar
Your battery is new, but is it charged? Check your voltage and make sure it's where it needs to be.
Old Jan 3, 2017 | 08:11 AM
What he said. If it starts when you connect an external battery, then that would indicate your start switch, start relay and electrical is ok.
reaper101
Jul 3, 2015 12:02 PM
reaper101
Jun 15, 2015 03:37 PM
Jubex7
Mar 18, 2013 07:57 AM
bambam
Apr 10, 2010 02:46 PM
cbrcamel
Jul 15, 2007 07:25 PM
