bike has not ran for 2 years
First post. Just picked up a 01' 929RR, from a Marine. He kept it in his garage for almost 2 years. So was wondering on the process of resurrecting this beast. Plan on draining the gas, getting a new battery and then trying to start it. Lmk what yall think of this, or what else I can do to make this thing easier to start. Thanks alot!
did it run before he stored it? if so, you should be good with the list you put up, however i would go on and change the oil. Great news for you is that with fuel injection your better off than a carb bike sitting for two years...fresh gas , new battery , and fresh oil. turn key and listen for the fuel pump to prime, fire that bad boy up...if performance is poor , add some seafoam feul treatment and run it , it will start to breakdown any crap in the injectors...good luck brother...my 01 929 is the baddest bike Ive ever rode, wicked stong, very flickable, and the front wheel is in the air at a flick...peece
good place to start... is your battery fully charged? note these bikes will not start with a weak charge, unlike a carb bike that needs fuel and spark, FI bikes wont act right even 10 v. If my 929's battery gets too weak , ill get the same "faint click" with no fuel pump prime.,You mention tip sensor, was the bike layed down? Any way , sounds like your on the right track, if you rule out all the simple stuff, checking the relay for power is a good start. Peece
