Bike acting up!!
Bike acting up!!
Hello all! I'm having some problems and I wondering if anybody can help me out. I have a 95 f3. Today I started the bike up in the garage and let it run. No problems. It ran fine. I hipped on it pull the clutch and engaged into first. No problems there either. So I shut it off and go back inside. I come back out 30 minutes later and push it out the garage so I could work on it. I was just putting my fairings back on the bike. After I put all the fairings back on, I hop on it to take it for a quick spin. I start it up. This time it sounds really choppy. I let in idle for a minute or two to see if it changes. No change. So I rev it up a lil bit and hold the rpms at like 2k. Still soundin choppy. So I open the throttle up , still choppy. So I say **** it, I'm gonna take the bitch down the street.[:@] I squeeze the clutch, lift the kick stand, click into first gear and then all of a sudden the bike shuts off! I try to start it with the clutch squeezed and nothing happens. So I put it in neutral. Start it up and click into first and it shuts off again. Is this a sign of my clutch going out. And would it just go out in a matter of minutes with no warning signs? As for the choppiness, I think it may be cause it's low on gas, but I'm no bike mechanic. Any help and suggestions is highly appreciated......Thanks in advance!!
RE: Bike acting up!!
how old is the gas that could have something to do with it if it was realy low over winter you could have gotten moisture in the tank and now in the carbs but that still wouldnt cause the bike to stall when put in gear are all grounds still hooked up did you pull anything off when putting on the fairings ????
