Bent Forks??
Old Jan 10, 2011 | 11:12 PM
Cbr_Guy322's Avatar
Default Bent Forks??
I dont know if my forks are bent or not. I cant really tell, whats the best way to check if they are bent.
Thanks.
Old Jan 11, 2011 | 12:54 AM
PlayfulGod's Avatar
first what happened to make you think they are bent? Forks cant get twisted in the triple in a crash. First thing to do is loosen all the clamps on the triples for the forks n let em resettle n retighten. If you're still experiencing whatever it is you're experiencing then have them checked.
Old Jan 11, 2011 | 02:07 AM
HenryM's Avatar
Did you hit something?
Old Jan 11, 2011 | 03:42 AM
jeason15's Avatar
if you want to eagle eye it, then take the bike out for a ride, and look at the bottom of the ignition in relation to the fairing stay, it should line up perfectly. you could also do the hands free test...
Old Jan 11, 2011 | 04:03 AM
Cbr_Guy322's Avatar
I low-sided my bike a while back and I'm trying to get parts to fix it right now and I just don't know if my forks are bent or not. But I will do what playfulgod said to do. I'll loosen the clamps and reset them and see if that fixes it. If it does then that will save me a lot of money.
Thanks for advice everyone.
Your some cool peoples. Lol
Old Jan 11, 2011 | 08:33 PM
brveagle's Avatar
My suggestion: Jack up the front of the bike. Pull the front axle/wheel off, loosen all the triple tree clamps, spin them around a bit, then tighten everything back together. If the axle goes through both forks nice and smooth, you're probably good. However if it binds, or if your forks look weird, time to invest in a new set.
The best way though is to just pull them off and examine them for creases.
Old Jan 12, 2011 | 01:57 AM
Cbr_Guy322's Avatar
Damn you guys know so much bikes. Cool people
Old Jan 16, 2011 | 11:29 AM
motorhorse's Avatar
jack up front wheel
loosen one sides upper+lower clamps
try to rotate the fork inside the clamps
tighten 1st side and repeat for the second side
if you can move it freely, forks are fine. bent forks will not move in the clamps(or will have resistance, causing wheel to move)
