Battery - jumed from car
I was jumping my dead battery ('02 600 F4i) and I jumped it from a car battery while it was running. I read some posts online and this is not good. I was able to start the motorcycle but the battery was completely dead and wouldn't run without jumper cables attached. Did I damage the bike's electical systems? I haven't gotten a new battery yet to test it. Thanks.
RE: Battery - jumed from car
dude never jump your bike from a car,the amps coming off your alt. is to strong for the bikes electrical system and my fry the voltage reg. or if it is fuel inj.fry the computer.like rjmech sugested use a batt. tender,you can get one enywere at my shop we sell 3 typs but the small one will do you just fine for about 32 bucks.
you may want to put a volt meter across your battery terminals to see what it reads both with the bike switched off and running. It will show the battery charge conditon but will also show if you've damaged your charging system as the volts should increase with the engine running.
you could have caused a problem with the ECU , it dosent like high voltage electrical spikes,
if you or anyone else reading this needs to jump start their bike with Fuel Injection, make sure the head lamp is on full beam and put as many lights on as you can (indicators, Brakes) these will take the voltage spikes out that damage resistors, diodes, & transistors, in the ECU, you might be lucky by having a completely dead battery, but always errr on the side of caution
