bank angle sensor?
how do you reset this can it be reset or does it need to be replaced
I think if you disconnect your battery for 5 min it might reset it. I'm not positive but I read that somewhere. Do you think it is bad? Have to tried bypassing it?
Turn ignition off and back on is all that is supposed to be required to reset it. You can turn on and cycle the kill switch a few times, then ignition off, back on and try.
Randyjoy i got the bas problem solved the bike started i hit the throttle a couple of times an let it idle it idled for about fourty seconds and quit havent been able to get it started since i checked the oil it was low rechecked all connections the fuel pump is engaging not sure whats going on any suggestions?
