Back fire
Old Jun 27, 2013 | 07:22 AM
Chillie2's Avatar
Unhappy Back fire
I own a cbr600 f3 1998, can anyone tell me why it pops going Down hill in a low gear
Old Jun 27, 2013 | 08:58 AM
CorruptFile's Avatar
June 2013 ROTM
Overrun. Typically its not a bad thing. It is caused by lean conditions when you roll off the throttle but the momentum (or gravity) keeps the bike moving. I found it more pronounced after putting a slipon on (less backpressure, yadi yah). Try sinking your carbs, might help.
Old Jun 27, 2013 | 11:34 AM
Chillie2's Avatar
Thanks c/f does this mean I will have to have the carbs balanced. This all happened when I put a K&N air filter, it seems to run lumpy on low speeds, but goes like hell when I am gunning it.
Old Jun 27, 2013 | 11:41 AM
June 2013 ROTM
Never hurts to check the balance, but in all likelihood it is a lean condition. Those K&N filters are a higher flow medium than oem. More air = leaner running. You may want to enrich your mixture a bit, that should take care of the bogging at low rpm and the popping on overrun.
Old Jun 27, 2013 | 12:31 PM
Chillie2's Avatar
Wink Thanks
Thanks c/f for your help. I think I will try the old ome filter to see how it runs. Thank you once again, all the very best, Jeff
suicidal
Oct 12, 2007 10:15 AM
flipsidef2
Dec 5, 2006 09:30 PM
DaVeRosi
Jan 22, 2006 05:33 PM
ConKhiSoMot
Oct 13, 2005 11:25 PM
ConKhiSoMot
Oct 11, 2005 11:15 PM
