Back brake failure
![Unhappy](https://cbrforum.com/forum/images/icons/icon9.gif)
This morning with my girlfriend on pillion, my back break just failed. The pedal seemed to had lost its resistance and would push all the way down without effect. I pulled over to check and all the springs were attached and in place, the break fluid container is full, and nothing seemed loose or broken. I got back on and after pumping a bit and leaving it for a while, I tried again and it worked. I stress tested it a bit more and it seems good again.
I've never had this, anyone else ever had this happen to them?
Sounds like air/moisture in the system. It's a good idea to flush/bleed the brakes
about every other season, to remove contaminants. I'm betting if you look at the fluid
it is a murky brown color. Do a search in the how-to mechanical for a good pictorial
and discussions on this procedure.
Ern
Ern
