Another misfire!!
I'm thinking of starting off with that yellow ground connector behind the clocks, I see lots of bad reports on it across forums. Hate the thought of taking tank and airbox off and pulling plugs, such a PITA WITH 954's, they're a pig to work on! Also wondering on my HIDs, had all three bulbs running them but the wiring kept arcing despite being really thickly insulated, bent down to hear where the crackling was coming from at one stage, and got my friggin ear fried, those things kick out big electricity!!
I have one running the dip now, and heard a crackle the other day when I started her with the lights on, hopefully get a dry day and run her without the lights on, that'll tell me if that's a prob fairly quickly
Narrowing that down should really be your first concern. But it probablly wouldnt be nessacary to start replacing every wire up there. Like my case for example my whole front harness was butchered and I found one fairly cheap on ebay and just replaced it. Not to say that you did something inccorrect with the HID wiring, but you really should in shrinking connections and wires where applicable. Heat shrink is cheap and also cheap insurance. Wiring isnt overly complicated. I mean you are created a loop of electricity. Its just if you start replacing a wire here and there it is going to get a little tedious trying to seperate wires from connectors and whatever. Depending on whatever wires you are reffereing to (aftermarket or factory) You probably better off disconnecting the whole harness and laying it out on the floor, it will give you a more complete job overall, especiallly if you do not know where your issue is plus you will get a chance to see everything. Plus the front harness isnt that complicated. You just have to be patient with wiring.
Yea mate, that sure sounds like a very unsafe thing. You sure dont want to be riding down the highway and catch on fire or something, could see all sorts of issues arising from that.
12hr night shifts are a PITA, sleeping during the day so can never get a chance to buy stuff and if I take the bike apart I'm severely limited on time to get it all back together again and we all know 954's are tedious to work on, those velocity stacks fry my head every time! lol
I suspect this bike was laid up for an extended period before I bought it and damp may have set in here and there, as I'd previously found the green disease on fuses etc. I can't see myself ever selling this bike, so don't mind going the extra mile on her and replacing stuff. I intend to gradually restore it to as good as new condition.
Well, the good news is that it def seems wet related. Took her out today and absolutely slammed it for around 15 miles, lights running, she was hammering on like a dream and razor sharp without any hesitancy or misfiring.
Now the prob is working out where the water is affecting things, I'm guessing that yellow block connector behind cluster? The more I thought about it getting into coil packs, the less likely it seems. But at least I've found the common denominator and am very happy to not be lifting tank etc lol
Might be time to retire on something completely weather proof, like a Blackbird lol
Hi Dec, yes the Blackbird is a brilliant bike , a mate had one, once we had removed the shock spacer , set up the sag and rebound, put the right profile tyres on, upgraded fork springs it handled a whole lot better, and really cheap bikes at the moment, but I would'nt let the 954 go
