For all you guys that painted your own bikes
Old Jun 27, 2006 | 12:22 AM
lotusgardener's Avatar
Default For all you guys that painted your own bikes
I have a quick question. How much paint did you order. I figure a pint should be more than enough to paint everything with two good coats. Any other input would be good.
Old Jun 27, 2006 | 01:18 AM
Illushun's Avatar
Default RE: For all you guys that painted your own bikes
For a full faired bike, a pint unreduced will work. When reduced 1:1, you should have enough. A few things will determine this. Whether or not your using an HVLP gun, if its basecoat/clearcoat, and if its urethane based and high solids clear. If you have a color that is close to what you will be getting, you can simply apply a base coat of that before you spray your actual color coat.
Also, to ensure good coverage, if you have plenty of clear, you could always throw down a flash coat of that before you spray anything. Spray pattern and gun pressure are keys to making it cover.
one last thing, if you are spraying over primer, a light color usually requires more paint to cover. But what i noted in the first paragraph would work.
Old Jun 27, 2006 | 03:51 PM
kreush33's Avatar
i bought a pint and still have a good amount left. I painted the side fairings a different color though, but there is still enough in the can that i would say i could have painted the fairings and still had plent left over. I sprayed silver too so it takes a couple coats to get good coverage.
Old Jun 27, 2006 | 04:17 PM
Ruthless's Avatar
Pint should be fine. Don't forget clearcoat. Goodluck.
Old Jun 28, 2006 | 02:31 AM
88sporty's Avatar
http://88sporty.blogspot.com/2006/06/blog-post_26.html
my picture fu is weak today.
I rattle can painted mine. the plastic was scratched/cracked etc, so I could not see putting mony into it.
BlackBy4
Aug 13, 2012 05:08 PM
CTcbr929
May 11, 2010 11:31 AM
f3racer
Oct 26, 2008 10:29 PM
Dragons Tail
Dec 21, 2007 02:16 AM
bmg velocity
Dec 18, 2007 02:42 PM
