All light kill switch?
how hard would it be to put an all light kill switch on a 97 f3?
Sorry If I sound confused, but what do you mean by 'all light kill switch'? Once you explain what it is you are trying to do I someone may be able to help you.
Originally Posted by Tal Destra
(Post 1094368)
Originally Posted by highwaypatrol
(Post 1094818)
He spliced all the wires to a single toggle switch, So to answer your question if your good at wiring it isn't difficult but side effect is remember it is seriously dangerous to drive with absolutely no lights at night (while probably speeding) |
Its not had at all. I did it for my f4i. It takes patience to route all the wires but it isnt hard. If your high beam works like the f4i's you just need to splice into one wire because our low beam controls highbeam so you just need to kill the power to the main one
Oh, I see! LOL! Thanks for explaining it to an old biker! Sounds a bit hairy to me, riding without lights to lose the blue and reds! Oh well, I suppose it's everyone to his own, but I wouldn't recommend it.
Originally Posted by jeffjones
(Post 1094826)
I believe what he wants is what my buddy had on his RX-7 when he would decided those blue and red lights behind him meant go.
Only legal, sane advantage would be starts on cold, winter mornings.
Yes, the relay kills the headlight while it's cranking. However, it's still on in-between bumps. So, if it's being a 'cranky-starter', it would conserve battery power. A 'powered-to-close-circuit' relay from the r/r might work, in that scenerio. Once the bike is running and sending power from the stator, the lights would automatically come on. Ern Ern |
no not for running from the po-pos... no point, my uncle is the judge
we play a game down here called hunter, if you can't be found at the end of it you win the pool, usually a 50$ entry |
Had it on my f2 pretty sweet turned off all my lights license running and headlight. I left my brake swirch intake for safety reasons not that anyone would be following me at high speeds anyway but id rathee not risk it.
| All times are GMT -5. The time now is 08:21 AM. |
