Airtech streamling gone, alternatives?
A few months back I lost my garage in a fire, with all the plastics for my 87 CBR600F. I was gong to consider that project dead, but decided to include replacement plastics in my insurance claim as the adjuster is not sure if they are covered or not.
I was going to price these out at Airtech Streamlining which I knew had a pretty comprehensive set of plastics available for this vintage.
Alas, I discovered that the company is no longer in business and, sadly, they seem to have tossed all the molds into the dumpster (!!!!) : https://www.gixxer.com/threads/airte...isness.852687/
Are there any alternatives ? Since I was never able to source even the small side maintenance panels, I'm considering going used to be a non-starter.
I've so far found this company: https://skidmarx.co.uk/all-products/...-front-fairing
thanks !
thanks !
thanks !
thanks !
The following users liked this post:
NuggyBuggyCBR (07-03-2024)
Looks like there are some here:
I found that AliExpress sells full sets of plastics for cheap, I just had to search for "plastics" instead of "fairings".
https://www.aliexpress.com/item/1005006068648445.html
They claim they can be "customized" by telling them what colour you want, words you want on it, etc. Which sounds weird. I'm not sure if they are accurate or not, they look a little different to me.
Anyone have experience with AliExpress plastics?
I've had good results with ebay/Ali fairings. Got couple sets over years for my race-bike due to occasional crashes. Before and after.
![](https://cbrforum.com/forum/attachments/general-tech-9/89826d172047108-airtech-streamling-gone-alternatives-ninja250bodyworkpurple.jpg)
Trick to getting fairings fitted is to only install each bolt 2-3 turns by hand. This allows you to tug and pull panels to fit later bolts. When all of them has been installed, go back and tighten them in multiple passes in criss-cross fashion. If bike's ever been dropped, even just garage tip-over, then mounting-brackets will be bent. Best to find pristine new bike and measure brackets to bend yours back to same shape.
Then couple rattlecans of paint and it's better than new!
![Smile](https://cbrforum.com/forum/images/smilies/smile.gif)
The following 2 users liked this post by dannoxyz:
Al1040 (07-19-2024),
NuggyBuggyCBR (07-09-2024)
