-   General Tech (https://cbrforum.com/forum/general-tech-9/)
-   -   Advice needed - new tires (https://cbrforum.com/forum/general-tech-9/advice-needed-new-tires-8975/)
nightsky point Feb 11, 2006 11:18 AM
Hi everyone on CBR Forum!
I have got new Metzeler Racetec K0 front and K2 rear tyres but have not them mounted yet. I have heard that new tyres have some protective layer on rubber surface, which is very slippy and dangerous. I have never been riding new tyres. Is this true and what should i do to remove that layer.
Thank you for your answers [sm=icon_cheers.gif]
Anubis Feb 11, 2006 12:05 PM
RE: Advice needed - new tires
Thats a decent choice of rubber you got there, I love mine.
Right......... New tyres have a thin layer of stuff on from the mold, i beleive its a releasing compound they use to help get them out the molds. It can cause you to have less traction in the dry but its more in the wet you need to be extra cautious,
Just Take it steady for the first 50 miles of use, (that means use not highway straight lines) and the coating will wear off easy. Perticular care at full lean angles.
Or as an alternative I do know of one man who gets the orbital sander out and takes the coating off with that to save him being so gentle, from the off.
L8X Feb 11, 2006 04:25 PM
i have also heard of people busting out the sander but youve got to be real careful!
1998f3 Feb 11, 2006 11:20 PM
Just put some slow steady miles on her w/ the new tires. I got metzler tires too. Good shiznit.
nightsky point Feb 12, 2006 06:56 AM
Thank you for your answers. I will try to use both of yours suggestions, sanding + slow driving. Just to make sure :D
See you
Anubis Feb 13, 2006 08:34 PM
You really don`t have to sand its just the bloke i know hates bedding them in, you don`t have to go that slow either just be steady with all your manouvres throttle, brakes, cornering.
1998f3 Feb 13, 2006 09:57 PM
I would think that sanding would be too risky. Just dont want to sand too much away. Thats just me though.
Tahoe SC Feb 14, 2006 01:40 PM
puhlease mofos...do not jack the tire by using sanders, etc...it's not going to do much for you. the tire needs to go through heat cycles mang...the sander will just make you lose some rubber...that layer comes off in a jiffy...just ride normal, not excessive leans, etc. for a few and you're good to go.
you need that heat cycle, not the sander...
ask yoself dis...what do mawfakis do on the track? scrub them in and let the heat cycle them! i busted brand spankin new diablos at the track...took it easy first lap, second lap more hardcore...by third lap i say FACK DIS and busted super duper thugged out hardcore...wish i had some corsas though...buahhahaha...
nightsky point Feb 14, 2006 01:50 PM
Ok, i just returned from mechanic with my tyres mounted on wheels. When i put them on the bike, i noticed strange thing. Looking from rear, patterns on both tyres look like this ˇ ˇ but rotation indicator on rear wheel shows that rear tyre is mounted incorrectly (reversed) If both rotation indicators look in the correct way then pattern on front look like ˇ and on rear ^. Who's correct, rotation indicator or my mechanic? Should i bring him back rear tyre to remount it?
Sorry i am quite inexperienced. Thanks!
nightsky point Feb 14, 2006 02:02 PM
wheels = rims, or something. Sorry, i am having hard time with English. Let me know if you can't understand any part of my posts :)
