99 Honda cbr900rr
To check the main fuse, you just need to pull it out and check continuity. I don't know your exact bike so you might need to look it up to find the exact location
If the bike turns over but won't fire, you will need to confirm spark. If you're experienced, there's an easy trick where you pull the plug, leave it connected to the ignition wires, ground it to the case, and turn the bike, watching for a spark. For a beginner I'd recommend an inline tester to make the job easier. Either way, I would start by downloading the manual and familiarizing yourself with the ignition system troubleshooting
MARTINEZ
04-07-2008 12:23 PM
